Discussion topic: My SkyQ Box keeps resetting
This message was authored by: Red+Riding+Hood
Whether I am watching Live TV or recordings my box has been resetting itself every 20 minutes or so. I'm aware of the problems last week and wondered if this is another incident causing the box to reset.
It does not go fully offline like last week and it will "come back" but it is very similar to the last incident.
anyone else affected?
Re: My SkyQ Box keeps resetting
Hi @Red+Riding+Hood
Try a Reset Settings in the Q box hidden menu.   This should stabilise it.
