Discussion topic: Sky cuts off multiple times each night. I have to reboot but 10 to 15mins later it will cut off agai
This message was authored by: Mike365
Sky Q freezes after working ok after reboot it is OK for about 15 to 20mins then freezes again.
Re: Sky cuts off multiple times each night. I have to reboot but 10 to 15mins later it will cut off
Hi @Mike365
