Discussion topic: My Sky box was unplugged for 24 hours. When turned back on, all recordings had been wiped. The first
This message was authored by tjno1 This message was authored by: tjno1
My Sky box was unplugged for 24 hours. When turned back on, all recordings had been wiped. The first programme I then recorded kept stopping briefly on playback. Any ideas?
Re: My Sky box was unplugged for 24 hours. When turned back on, all recordings had been wiped. The f
Hi @tjno1
Have you checked in the Recordings- Manage - Deleted section to see if your recordings are there?
Try a Reset Settings in the Q box hidden menu this will not bring back recordings if they have been deleted but is may improve the box functions.
tjno1
Thanks. I will try that. I did check deleted items and it was empty, as was scheduled recordings.
