5
This discussion topic has been answered Discussion topic: SCAFFOLDING BLOCKING SKY DISH SIGNAL
This message was authored by: RafiRoxi123
HI WE Have scaffolding up around our flats and its blocking the signal. who do we contact at SKY to have the dishes relocated at scaffolding will be up for months.
Anybody got a number ?
thanks
Re: SCAFFOLDING BLOCKING SKY DISH SIGNAL
@RafiRoxi123
Even if you have Sky Q Sky will charge you approximately £65 for a dish move in these circumstances providing there is another suitable spot for it. If you have Sky+ as @GD1 states you'll need to employ a local satellite company at your own expense.
I'm assuming from your post,that you're not connected to a communal dish.You can find the number to call via the 'need more help' link at the bottom of the page here:https://www.sky.com/help/home
Avatar for RafiRoxi123
Thanks no we dont have a communal dish
@RafiRoxi123  Do you have Sky Q or Sky+HD?  If the latter SKy no longer support these boxes therefor any dish resiting would be out your own cost and you'd need to get an independent installer to carry out any works.
@RafiRoxi123
ok thanks Ive spoken to SKY theyre sending an engineer out
