Discussion topic: My Sky Q box cannot connect to my router
This message was authored by: Jona111111
my Sky CuBox cannot connect to my router. I have gone through the on-screen instructions, but it has not worked. The last instruction told me to press the WPS button on my broadband router. But there is no WPS button on my broadband router, so I pressed the one on my sky Q box. But it did not work
Re: My Sky Q box cannot connect to my router
@Jona111111 what broadband router do you have ? if its the Sky SR203/4 the upright broadband hub the WPS button is onthe thin edge of the right handside of the router
Hi @Jona111111
Pressing the WPS button just on the Q box will not help.
With Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
As you are on Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.  WPS button shown below
