Discussion topic: My Sky Mini box won’t switch on
Message posted on 29 May 2023 09:57 PM
My sky box mini stopped working several days ago, tried everything got it working once now it's not working again
main box is fine
any ideas on how to fix?
Message posted on 29 May 2023 10:20 PM
Re: My Sky Mini box won’t switch on
main box is fine
Hi @Philly1960
Have you tried switching the mini on using the Standby button on the right front of the mini (the Amber Led).
If this brings the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 13 Oct 2025 07:53 PM
Thankyou sooooo much for your advice. Spent 3 hours on that infernal robot chat which ended with it saying I needed a new box. As it was less than a month old doubted this was the case. Searched high and low for suggestions and yours was the one that worked. Thank you
