Discussion topic: Apps display
This message was authored by: PG59
Apps display
My replacement sky q box is not displaying, how do I fix this
Re: Apps display
Hi @PG59
Have you tried rebooting your Q box?
Failing this
Try refreshing the Apps in the Q box Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Re: Apps display
Hi @PG59   Have you checked that your replacement box's software to up to date, Q320 or above.
