1
This discussion topic has been answered Discussion topic: My Q box buzzes loadly at times. Far more than it use to. i need an engineer but sky not helping..
This message was authored by: Kwaka
My Q box has started to buzz quite loudly at times and it's so loud we have to turn the TV up to mask it. Tried for an engineer but it seems sky bot dosnt want you to speak to a hunan. Is there any sky person out there. When you pay £111.00 amonth some kind of human service should be available easily and quickly.
Re: My Q box buzzes loadly at times. Far more than it use to. i need an engineer but sky not helpin
Hi @Kwaka
Try a Reset Settings in the Q box hidden menu.   See if that helps.
Hi @Kwaka
Answered - Go to Answer
