Discussion topic: My ITV/STV channel 103 isn’t working
Re: My ITV/STV channel 103 isn’t working
These sort of problems are almost entirely down to dish alignment issues, even if it only seems like a single channel such as ITV is affected. Sky should be sending out an engineer to check the dish alignment.
This message was authored by: Cer1
Same! My ITV channel has not worked since February. Just keeps saying satellite not working. But only on that one channel? Tried the reboot
@Cer1
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
