Discussion topic: My ITV/STV channel 103 isn’t working
Message posted on 10 Oct 2023 11:46 AM
My ITV has been off for over an hour! Is this a technical issue with the ITV channel?
Message posted on 10 Oct 2023 11:50 AM
Re: My ITV/STV channel 103 isn’t working
@Alexandra21 Unlikely to be a channel specifi issue given the lack of posts.
Have you tried a reboot?
Message posted on 10 Oct 2023 11:56 AM
No I've not tried to reboot! I have multi room & it's on both tv's but will try & reboot.
Message posted on 10 Oct 2023 12:31 PM
Reboot the main box first, then any mini boxes.
1 - Using the Sky Q remote put the box into standby
2 - switch the box off at the plug
3 - wait at least 30 seconds
4 - switch back on at the plug
5 - follow the on-screen instructions
6 - when the screen goes black and the blue ‘Q’ stop pulsating wait another 30 seconds
7 - press the 🏠 button
Message posted on 13 Oct 2023 09:17 AM
Did you get anything to work as I have been in holiday and my itv has been off since I got back yesterday, I rebooted my main box and the hub but still not working
Message posted on 13 Oct 2023 10:06 AM
Are you seeing any error message when trying to view 103?
Message posted on 13 Oct 2023 10:14 AM
Yes, it says no satellite signal but only for that channel
Message posted on 13 Oct 2023 10:15 AM
@Brixx30
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Message posted on 13 Oct 2023 10:51 AM
Thanks, as it's only one channel it says it's a broadcaster issue, very annoying but I'll keep trying thanks for your help
Message posted on 13 Oct 2023 10:58 AM
@Brixx30 wrote:...as it's only one channel it says it's a broadcaster issue
A slight satellite dish pointing error will only effect reception of a few satellite transponder signals.
Godfrey.
Message posted on 13 Oct 2023 11:00 AM
@Brixx30 wrote:Thanks, as it's only one channel it says it's a broadcaster issue, very annoying but I'll keep trying thanks for your help
Which ITV region are you in? There will be other channels on the same transponder you can test, depending on your region.
It will almost certainly be a dish issue requiring an engineer visit rather than a broadcaster issue.
Message posted on 21 Oct 2023 03:20 PM
I haven't been able to get channel 103 STCV HD since Wednesday 1u8th October. After spending an hour on the phone to the technical department got cut off!
Message posted on 02 Nov 2023 05:04 PM
I have the same issue, it seems to be daily when the Chase in ON, not sure if that is relevant or not but channel 803 works ok!?
Message posted on 08 Dec 2023 12:00 PM
803 works for me too - i called sky today but they couldnt resolve the issue with 103 and directed me to call ITV! This is really frustrating
Message posted on 10 Dec 2023 05:28 PM
Same issue here (in Auchterarder). Sly attitude awfulun pointing to ITV.
It was working, it isn't now and something between Sky and ITV has changed. It is their responsibility to fix on bahalf of their CUSTOMERS.
