Discussion topic: Multiview
Message posted on 24 Aug 2025 02:38 PM
Multiview
Does anyone have the multiview option to watch Sunday matches simultaneously?
Message posted on 24 Aug 2025 02:42 PM
Re: Multiview
@Jason71969 As i noted last week on another thread multiview is only to be used when there are four or more games being played simultaneously
Message posted on 24 Aug 2025 02:43 PM - last edited: 24 Aug 2025 03:19 PM
Re: Multiview
There are two 1400ko matches today, both being broadcast live. I believe it has to be 4 games on at the same time before it's available. That's more likely on a Sunday @ 2pm when some PL teams have played midweek in Europe (in particular Thursdays).
Message posted on 24 Aug 2025 02:44 PM
Re: Multiview
Thanks for quick response but the Sky website says up to 5 concurrent games?
Message posted on 24 Aug 2025 02:54 PM
Re: Multiview
Presumably 'up to 5' once that trigger threshold is reached.
Re: Multiview
@Jason71969 wrote:Thanks for quick response but the Sky website says up to 5 concurrent games?
@Jason71969 can you post a link to where you're seen this so i can get it checked out as it would appear to be incorrect
Message posted on 24 Aug 2025 03:17 PM
Re: Multiview
Apologies, my entry earlier was a typo, should have been 4.
Message posted on 24 Aug 2025 03:21 PM
Re: Multiview
I think the relevant section in the link you've posted is this…
For match weeks following midweek European action, when up to four matches may be played simultaneously due to fixture displacement, Super Sundays on Sky Sports will be supersized. For viewers wanting to keep an eye on all the live action, a new programme called Multiview will launch across all Sky TV platforms
