1
This discussion topic has been answered Discussion topic: Multiroom
This message was authored by: Booper1
Multiroom
My multiroom box won't connect to my broadband or skyway box
Re: Multiroom
Hi @Booper1
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Re: Multiroom
Hi @Booper1
