Discussion topic: Mini Box losing connection to Sky Q box when trying to play recordings.
Message posted on 17 Dec 2025 01:41 PM
I have a problem with one sky mini box. It connects to the main box absolutely fine for almost everything but when a recording is selected the box freezes and then displays the message that the box cannot connect to the main box.
Contacted Sky and they replaced the mini box as all of the other troubleshooting steps did not work. Again, all trobuleshooting steps haven't helped and the problem remains. What is happening?
Message posted on 17 Dec 2025 05:02 PM
Re: Mini Box losing connection to Sky Q box when trying to play recordings.
Hi @Jaybe1972
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
Message posted on 17 Dec 2025 05:16 PM
I already tried all of that prior to being sent a new mini box. I also have a WiFi extender and it's plugged in the same room as the box I'm having issues with but thanks for your suggestions. It's an odd problem and nobody, not even Sky themselves, seem able to fix it. Might it be the main Q box at fault? I have had the odd connection issue with another mini (which the reset seemed to have resolved) but nothing on this scale.
