Discussion topic: Mini screen on tv
This message was authored by: Danny2004
Mini screen on tv
The last Chanel mini screen won't go away and keeps coming back. I have switched off my sky box twice but it keeps coming back and won't go away.
Re: Mini screen on tv
Hi @Danny2004
