Discussion topic: Multiroom saying weak signal
Message posted on 07 Aug 2023 04:17 PM
The multiroom is saying weak or no signal. Mainbox is working fine. Done the usual switch off and on. When I switch the multiroom box off and on after a while it comes up with "BBC2 and some other text" in a 25mm square on the left hand side of the screen which quickly disappears and then I get the weak or no signal message. The Wifi seems to be OK.
Message posted on 07 Aug 2023 08:32 PM
Re: Multiroom saying weak signal
@Fozboz who is your broadband provider ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 13 Oct 2024 05:28 AM
If youhave wifi problems due to a weak signal, being so far away from the router, you can buy a Wifi extender. I can watch SKY in my shed whiich is about 40 metres from my Router. I bought TP-LINK 300M WiFi Extender Booster & 600Mbper second Powerline kit from Argos for £44.99. I now have Wifi signal anywhere on my property/grounds.
