Discussion topic: improving wifi signal when using Sky Q, Sky mini boxes and booster
Message posted on 22 Aug 2024 05:52 PM
i have sky Q. the router is ethernet connected to a booster and to one sky mini box. the main sky Q box is connected to wifi (not far from the booster). there's a second sky mini box that is sometimes switched on, sometimes switched off.
my problem is that the wifi signal strength in the room where the ethernet-connecte sky mini box is placed is very poor. i had thought the sky mini box would emit wifi signal (solving for that room) but it is weak.
thank you.
Message posted on 22 Aug 2024 06:05 PM
Re: improving wifi signal when using Sky Q, Sky mini boxes and booster
Hi @gnl Have you checked that the hotspot is turned on? https://www.sky.com/help/articles/wifi-hotspots
Message posted on 22 Aug 2024 06:51 PM
@gnl if Sky is your broadband provider then the hotspots are turned on by default and there is no optrion in setup > advanced settings to turn them on/off
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Aug 2024 09:48 PM
Thanks for those comments. I checked and I have no option to turn hot spots on or off. I also reset the Sky mini box that is connected to ethernet in order to ensure it was running off that ethernet connection rather than off wifi. This has improved it marginally but it is still a weak signal.
Any other thoughts appreciated. Am happy to buy more boosters/ routers/ etc if that would help. The broadband speed is fine; it's the signal strength in certain places that's a bit weak.
Thanks.
Message posted on 13 Oct 2024 05:31 AM
If youhave wifi problems due to a weak signal, being so far away from the router, you can buy a Wifi extender. I can watch SKY in my shed whiich is about 40 metres from my Router. I bought TP-LINK 300M WiFi Extender Booster & 600Mbper second Powerline kit from Argos for £44.99. I now have Wifi signal anywhere on my property/grounds.
