Discussion topic: Multi screen
This message was authored by: LittleAlexx
Multi screen
I'm thinking of getting an additional box for the multi screen. I currently have Sky Q. Do I just connect the box to a tv for it to work?
Re: Multi screen
For Q multiscreen you need a subscription (around £15 per month) and a mini-box (Around £50 admin charge).
...then, yes, you connect the mini-box to your TV via HDMI cable and can watch (non-UHD) recordings and live TV sent by the main Q box.
Avatar for LittleAlexx
Re: Multi screen
Thank you, I thought that was the case but I wanted to be sure.
Re: Multi screen
@LittleAlexx
Remember that Q Mini boxes have never been capable of UHD output, if that's important for you.
Re: Multi screen
Thank you, it isn't though. I won't need an engineer though will I?
Re: Multi screen
You shouldn't but sometimes they insist.
Re: Multi screen
Thank you for your help.
