Discussion topic: Multi room
This message was authored by: Edwardporter196
Multi room
I have two mini boxes in different rooms and neither is working
Re: Multi room
@Edwardporter196
If you provide more information someone may be able to help.
HAPPY NEW YEAR
Re: Multi room
@Edwardporter196
The first thing to try is always to remove and then replace the power supply to the main Q box.
Re: Multi room
Hi @Edwardporter196
Reboot the minis as above. start with the one nearest to the main Q box (or if on Sky broadband Sky router if nearer than the main Box)
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. When connecting the second mini you can use WPS on the first mini if nearest.
