Discussion topic: Multi room
Message posted on 25 Jan 2024 02:39 PM
Multi room
I have two mini boxes in different rooms and neither is working
Message posted on 25 Jan 2024 03:54 PM
Re: Multi room
If you provide more information someone may be able to help.
Message posted on 25 Jan 2024 03:55 PM
Re: Multi room
The first thing to try is always to remove and then replace the power supply to the main Q box.
Message posted on 25 Jan 2024 04:00 PM - last edited: 25 Jan 2024 04:03 PM
Re: Multi room
Reboot the minis as above. start with the one nearest to the main Q box (or if on Sky broadband Sky router if nearer than the main Box)
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. When connecting the second mini you can use WPS on the first mini if nearest.
