2
This discussion topic has been answered Discussion topic: Multi room not working
This message was authored by: AvS
new multi room not working
Re: Multi room not working
Hi @AvS
Reboot the mini as above.
Hi @AvS
Avatar for AvS
Thank you. Working now
Answered - Go to Answer
