Discussion topic: Multi room keep losing connection
Message posted on 05 Jun 2024 08:20 PM
Multi room box having a problem finding my Sky Q box
Message posted on 05 Jun 2024 08:52 PM
Re: Multi room keep losing connection
Hi @Weedo1975
Reboot the mini as above.
