Discussion topic: Remote not working
Message posted on 05 Jun 2024 08:14 PM
Remote not working
Hi my remote is not working. I've changed the batteries, I've pressed 7&9 and nothing happens. I can't do anything with the remote.
Please advise
Message posted on 05 Jun 2024 09:28 PM
Re: Remote not working
Please advise
@Paddy16 Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
