2
This discussion topic has been answered Discussion topic: Multi room device frozen with error code MR108 also now handset will not do anything this problem oc
This message was authored by: Barry591
Multiroom device frozen with error code MR 108 now handset will not work either searches for internet but states problem activating your Sky mini box
This message was authored by: Laing1 Answer
Re: Multi room device frozen with error code MR108 also now handset will not do anything this proble
@Barry591 Have you tried rebooting your main Q box ie
then
reboot your mini box
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
then
then
Avatar for Barry591
Thank you Laing all working now wasn't sure about remote but it worked thanks again
@Laing1
Answered - Go to Answer
