Discussion topic: Multi room box not working
This message was authored by: Mkenymccabe
Just received a new Q box now up an running fine however I am now unable to get my mini sky box, tried all suggestions but still isn't working
Re: Multi room box not working
Hi @Mkenymccabe
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
