Discussion topic: Multi room box not working
This message was authored by: Paul16041974
Re: Multi room box not working
@Paul16041974
We'll need a bit more info in order to try to offer some help.
HAPPY NEW YEAR
Avatar for Paul16041974
Level 0 icon
Tried all the usual things and the box light is still red and nothing working
@Paul16041974
Have you rebooted the main box first, then when that's back up and running doing the same to the mini box (if it lets you)
~ press the 🏠 button
HAPPY NEW YEAR
Level 0 icon
Done all that numours of times
