Discussion topic: Multi room box not working
Message posted on 15 Dec 2023 06:46 PM
Message posted on 15 Dec 2023 06:56 PM
Re: Multi room box not working
We'll need a bit more info in order to try to offer some help.
HAPPY NEW YEAR
Message posted on 15 Dec 2023 06:58 PM
Tried all the usual things and the box light is still red and nothing working
Message posted on 15 Dec 2023 07:02 PM
Have you rebooted the main box first, then when that's back up and running doing the same to the mini box (if it lets you)
~ press the 🏠 button
HAPPY NEW YEAR
Message posted on 15 Dec 2023 07:04 PM
Done all that numours of times
