5
This discussion topic has been answered Discussion topic: Multi View
This message was authored by: SMD10
Multi View
How do I get a multi voice football match on full screen I don’t want to see team info
This message was authored by: nigea99 Answer
Re: Multi View
@SMD10 wrote:
Hi Guys gone on via App have full screen not great picture as internet not great. Would still like to know dismiss button. Thanks
hi @SMD10
AKA Back button
Left of the Home button <-]
Re: Multi View
I believe pressing the dismass button a couple of times gets you to full screen..
Or, going into it via the App rather than the red button.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Re: Multi View
Hi @SMD10   Guaranteed way is to use the Menu system. If you are using the Red button, try dismissing a few times.
Avatar for SMD10
Re: Multi View
What is the dismiss button on my Sky Q remote
Avatar for SMD10
Re: Multi View
Re: Multi View
hi @SMD10
AKA Back button
