Discussion topic: Sky mini box
Message posted on 26 Aug 2026 08:36 PM
Sky mini box
I have been given a mini box today and it's still not working can not get any of the apps working at all
Message posted on 26 Aug 2026 08:40 PM
Re: Sky mini box
Given by who? They are only loaned by Sky.,
Message posted on 26 Aug 2026 08:45 PM
Re: Sky mini box
Yes sky replaced it for me today and took away the old box, however none of the apps are working and it's saying there's an issue with the box on my sky app
Message posted on 26 Aug 2026 08:48 PM - last edited: 26 Aug 2026 08:49 PM
Re: Sky mini box
Hi @Cazza82
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
