Discussion topic: Multi Room Box Issue
This message was authored by: Fountain+A
Most days at about 13:00 my Multi Room box stops working or looses sound for a few minutes. This never happens at other times.
It also is very slow.
Re: Multi Room Box Issue
Hi @Fountain+A Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with the Mini box?
