Discussion topic: Mulitscreen isnt working
Message posted on ‎21 Aug 2024 09:20 AM
Hi, my multiscreen isn't working
Message posted on ‎21 Aug 2024 10:22 AM
Re: Mulitscreen isnt working
Hi @areid1987
Reboot the mini as above.
