Discussion topic: My mini sky q in my bedroom wont **bleep** on jus red light
This message was authored by: Hockey
My mini sky q box in my bedroom won't **bleep** on iv tried since lastnight
Avatar for Hockey
Level 0 icon
Re: My mini sky q in my bedroom wont **bleep** on jus red light
My mini sky q box in my bedroom isn't working
Hi @Hockey
Reboot the mini as above.
