3
This discussion topic has been answered Discussion topic: Muffled sound on Sky Channels
This message was authored by: CliveStringer
Sound very muffled on Sky Atlantic, Witness, Movies amongst others. Ok on +1, BBC, ITV etc ok so it's just the Sky channels.
Tried unplugging and leaving for a minute several times but to no avail. Any solution would be appreciated.
This message was authored by: nigea99 Answer
Re: Muffled sound on Sky Channels
hi @CliveStringer
What are you listening via - A Tv, Sound bar or AV receiver etc ?
What setting is in :
Home - Settings - Setup - Audio Visual
Digital audio output HDMI
If it is DD what does it sound like if you set to Normal ?
hi @CliveStringer
Avatar for CliveStringer
It was on DD+ I've changed it to Normal and the sound seems corrected now. Thankyou!
hi @CliveStringer
It seems that your audio equipment may have difficulty with the Centre channel with 5.1 sound - leaving it on Normal uses 2.0 ( just left & right hand channels)
Glad setting it Normal works for you 🙂
