Discussion topic: Mr
This message was authored by: Colin165
Mr
There's something wrong with my sky box it's not coming on
your since Colin
Re: Mr
What happens if you power it off at the wall and back on?
Re: Mr
Firstly, try a restart of your Sky Q box;
  1. Press standby on your Sky Q remote, then switch off or unplug your box at the mains.
  2. Check there are no lights on the front panel of your Sky Q box and all cables are securely connected.
  3. Plug in and switch your Sky Q box back on at the mains.
  4. Wait for the on-screen instructions to disappear then press Home on your Sky Q remote. Some features may take up to 5 minutes to return.
If that does not help, try the recovery procedure as detailed in this Sky help article;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
