1
This discussion topic has been answered Discussion topic: Moving sky mini box
This message was authored by: Scott+Jewell
Moving sky mini box
Can I move my sky mini box from one TV to another in anorher room or does a sky engineer need to move it ?
Re: Moving sky mini box
Hi @Scott+Jewell
You can move it and connect to a different Television.
It doesn't need an Engineer.
You may have to complete the following if it doesn't connect at the new location.
Reboot the mini as above.
Hi @Scott+Jewell
