This discussion topic has been answered Discussion topic: Moving sky mini box
Message posted on 07 Aug 2024 01:25 PM
Can I move my sky mini box from one TV to another in anorher room or does a sky engineer need to move it ?
Message posted on 07 Aug 2024 01:29 PM
You can move it and connect to a different Television.
It doesn't need an Engineer.
You may have to complete the following if it doesn't connect at the new location.
Reboot the mini as above.
