5
This discussion topic has been answered Discussion topic: Moving home and unable to have satellite dish
This message was authored by: oscardooo
I'm moving home next week and have been told we are unable to put up satellite dish and the internet connection is with see the light  does anyone know how this would work as I have sky Q and multi room  not even allowed a tv Ariel not really wanting to cancel sky as just resigned for another 18 months
This message was authored by: hrai Answer
Re: Moving home and unable to have satellite dish
@oscardooo
I had a quick look at their site and they do have a section dedicated to Sky, specifically Sky Stream (tbh it's probably a tie in with Sky to push Stream)
It does suggest that if you go the Glass (or Stream) route that there won't any issues regarding the ISP
@oscardooo
You will have to call Sky to discuss your options but it seems the Sky Q option is out. I've not heard of that broadband company to know if it suits Sky Glass / Stream.
@oscardooo
Avatar for oscardooo
Many thanks  will be on to Sky asap to see what I need to do
@oscardooo
See the Light (an ISP on the OFNL network) has actually been owned by Sky Group for several years, hence the branding at the top of their website
https://www.ispreview.co.uk/index.php/2019/09/sky-get-wholesale-access-to-buuk-full-fibre-broadband-...
However you'll find almost no awareness of this within Sky television/broadband support or sales, and moving to a property supplied by STL isn't a 'switch' of ISP under the Ofcom scheme or a Home Move.
Thanks for all the help
Answered - Go to Answer
