4
This discussion topic has been answered Discussion topic: Moving House
This message was authored by: Lindablue
Moving House
The wires from my Sky Q box are drilled into and through the wall to the outside. When I move do I just detach the Qbox from
the wires and  take just the box with no wires attached  to my new home for the Sky engineer to attach new wires. Any help would be appreciated,  Im 83 and live alone, so having difficulty.  Thanks in advance for any  help.
Re: Moving House
Yes @Lindablue
You leave all the Wires.
Provided you have carried out a Home move through Sky the Engineer will install a new dish if necessary and also a new set of cables if required
Re: Moving House
Yes @Lindablue
Avatar for Lindablue
Level 0 icon
Re: Moving House
Many, many thanks for your help. 👏👏👏
Re: Moving House
Hi @Lindablue   Have you booked your Home Move? Yes unscrew the satellite leads and only take your box, power cable, HDMI lead and remote control. The same if you have any Mini boxes. The installer will put up a new dish and new satellite leads if required.
Level 0 icon
Re: Moving House
Thankyou 👍👍👍
