Discussion topic: No satellite signal
This message was authored by: Mulberry785
No satellite signal
I can not access my tv programs
I have tried settings but nothing resolves the problem
the message is :-
this channel is currently affected by a problem with your satellite signal.
this applies to all channels
Re: No satellite signal
@Mulberry785
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
