Discussion topic: Movies buffering.
This message was authored by: Stu315
Movies buffering.
I left Sk6 because of movies constantly buffering. When I came back I opted for 500 mbps download speed so I should not encounter the same problem. However for the past couple of weeks I have not been able to watch a movie without it buffering sometimes for a good few minutes. Sick of it. Router looks fine, I always suspected I had issues with the Sky Q top box as I always needed ethernet cable to connect it after it reset.
Re: Movies buffering.
Is this on apps like Netflix/Disney+ etc? The Sky Cinema channels are delievered over satellite, and On Demand movies from Sky are downloaded rather than streamed so don't buffer.
Avatar for Stu315
Yeh, we have realised this. It is Disney+ that seems to be buffering a lot. We have been trying a few sky movies tonight with no apparent issue, it only happened on Disney. The router is testing good with 503 download speeds so I thought this would allow better streaming.
If you have not tried already.
Resatart you main Sky Q boxes:
  1. Press Standby on your Sky Q remote, then switch off or unplug at the mains and wait for the lights on your Sky Q box to turn off.
  2. Plug in and switch your Sky Q box back on at the mains.
  3. Wait for the on-screen instructions to disappear then press Home on your Sky Q remote.
Refresh your apps:
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
    The refresh can take 24 hours to complete.
Also, try a restart of your broadband router.
Avatar for Stu315
Cheers Lettice.
I have followed your guidance and will now give Disney+ another go. Thanks buddy.
This message was authored by: Ash145
On satellite movie channels and slightly affecting sky sports
Just sky movies
If this is happening on satellite channels and not streaming services, it's a totally different problem. Probably a dish alignment issue.
