Discussion topic: Sky q mini both not connecting after house move
This message was authored by Claz1983 This message was authored by: Claz1983
Hi, we have just moved house and the sky engineer came and did the installation of the main box but didn't touch the sky q mini. We connected the boxes and reset them and still saying no signal. Does anyone know what I need to do to get signal.
Re: Sky q mini both not connecting after house move
Hi @Claz1983
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Claz1983
Thank you. I have tried doing all that's mentioned but still not working. They were both fine last week but since moving they aren't working and the sky engineer never checked them when he fitted sky yesterday.
When you say not working @Claz1983
Exactly what is happening?
Are they switching on?
If so what message do you see immediately after you switch on?
Also information on your Broadband supplier and the approximate distance and location of your router and Q Boxes would help
Claz1983
I switch them on and it says no signal. The minis are in the bedrooms above my living room which is where the main box is and WiFi hub. 3.5 metres
