Discussion topic: Move SkyQ Box
Move SkyQ Box
Hi, I've got a new TV stand and want to move my SkyQ box and need to remove the cables to feed them through the back of the TV stand. I can remove the power cable and HDMI cable no problem, but there are two satellite cables that are difficult to remove and I don't want to damage them... are they OK to remove or are they a permanent fitting?? Thanks in advance
Re: Move SkyQ Box
You need to unscrew them to release.  Then pull them out straight.  (Reverse to refit)
