Discussion topic: Mounting Sky Box
This message was authored by: eslater98
Mounting Sky Box
Redoing our front room. Looking to wall mount the tv and wondering if I wall mount our sky a box behind the tv will it still work.
if not and I have to place it on the shelf we have is there a way to tidy it bluetooth the cables going from the box to the tv
This message was authored by: bob1234
Re: Mounting Sky Box
@eslater98Yes it should work mounted behind your TV they don't seem to overheat, mine is stuck on the back of the bedroom TV with sticky velcro.
EDIT
The Q box should also work BUT they need lots of air circulation so they don't overheat. forget the bit about velcro.
@eslater98
You've posted on the Sky Glass board but your post seem to mention a Sky a box - do you mean you have Sky Q?
This message was authored by: SlenderRobert
You mention a Sky 'a' box. Do you mean a Q box or a Stream puck as this is the Glass/Stream forum?
Avatar for eslater98
A sky q 1tb box - I couldn't work out how and where to post it sorry
@eslater98
No problem. I've moved it for you.
@eslater98  Your post has been moved to the Sky Q forum.
No, there isn't a realistic way to output
video and audio wirelessly instead of with HDMI. Such technology does exist but is notoriously unreliable.
This message was authored by: Kyle+M
It should still work.
Depending on
If you have a Bluetooth remote (has voice control) .  If it is then it will work. If not then it won't.
But it could impact the wifi signal putting the box behind a TV.
If you have mini boxes then the signal will get a little worse more then likely will still work though.
