Discussion topic: Mounting Sky Box
Message posted on 27 May 2023 03:59 PM
Mounting Sky Box
Redoing our front room. Looking to wall mount the tv and wondering if I wall mount our sky a box behind the tv will it still work.
if not and I have to place it on the shelf we have is there a way to tidy it bluetooth the cables going from the box to the tv
Message posted on 27 May 2023 04:03 PM - last edited: 27 May 2023 04:22 PM
Re: Mounting Sky Box
@eslater98Yes it should work mounted behind your TV they don't seem to overheat, mine is stuck on the back of the bedroom TV with sticky velcro.
EDIT
The Q box should also work BUT they need lots of air circulation so they don't overheat. forget the bit about velcro.
Message posted on 27 May 2023 04:08 PM
You've posted on the Sky Glass board but your post seem to mention a Sky a box - do you mean you have Sky Q?
HAPPY NEW YEAR
Message posted on 27 May 2023 04:09 PM
@eslater98 wrote:Redoing our front room. Looking to wall mount the tv and wondering if I wall mount our sky a box behind the tv will it still work.
You mention a Sky 'a' box. Do you mean a Q box or a Stream puck as this is the Glass/Stream forum?
Message posted on 27 May 2023 04:16 PM
A sky q 1tb box - I couldn't work out how and where to post it sorry
Message posted on 27 May 2023 04:19 PM
No problem. I've moved it for you.
HAPPY NEW YEAR
@eslater98 Your post has been moved to the Sky Q forum.
Message posted on 27 May 2023 05:59 PM - last edited: 27 May 2023 06:00 PM
No, there isn't a realistic way to output
video and audio wirelessly instead of with HDMI. Such technology does exist but is notoriously unreliable.
Message posted on 27 May 2023 08:04 PM
It should still work.
Depending on
If you have a Bluetooth remote (has voice control) . If it is then it will work. If not then it won't.
But it could impact the wifi signal putting the box behind a TV.
If you have mini boxes then the signal will get a little worse more then likely will still work though.
