Discussion topic: More sky TV
Message posted on 07 Jun 2025 08:04 PM
More sky TV
Message posted on 07 Jun 2025 08:06 PM
Re: More sky TV
@Michelle219 Which sky tv platform do you have
sky Q glass or stream
Message posted on 07 Jun 2025 08:08 PM
Re: More sky TV
Erm I'm not to sure just sky q I think
Message posted on 07 Jun 2025 08:20 PM
Re: More sky TV
You need minis and a multiroom sub (15 a month I think)
Message posted on 07 Jun 2025 08:25 PM
Re: More sky TV
@Michelle219 wrote:
How do I go about getting sky in other bedrooms and how much more a month is it
You mentioned bedrooms plural.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Message posted on 07 Jun 2025 08:38 PM
Re: More sky TV
Sorry I ment to put just my bedroom
Message posted on 07 Jun 2025 08:45 PM
Re: More sky TV
That's fine then.
