Discussion topic: IP ADDRESS
Message posted on 14 Mar 2025 06:13 PM
IP ADDRESS
How do I find out my sky Q IP ADDRESS
Message posted on 14 Mar 2025 06:18 PM
Re: IP ADDRESS
Hi there
Do you mean 192.168.0.1 for the hub?.
Message posted on 14 Mar 2025 06:19 PM
Re: IP ADDRESS
Message posted on 07 Jun 2025 10:12 PM
Re: IP ADDRESS
I have found my IP address via your instructions, thank you. Can you also tell me where i find the Gateway and DNS settings (I am having a lot of trouble connecting my TV) I have inherited the TV, so do not have instructions. THanks again
Message posted on 07 Jun 2025 10:24 PM
Re: IP ADDRESS
Do you mean you're having problems connecting the Sky box to the new TV? You don't need IP/DNS etc details to do that.
Message posted on 07 Jun 2025 10:53 PM
Re: IP ADDRESS
The gateway and DNS are both the local IP address of your router. Automatic IP configuration should pick this up without having to specify it manually.
Message posted on 07 Jun 2025 11:47 PM
Re: IP ADDRESS
@HF5 wrote:How do I find out my sky Q IP ADDRESS
Firstly, you'll need to connect your Sky Q box to the Internet, either via WiFi or via an ethernet cable.
Once done,
- Press the HOME button (black button above the blue microphone button)
- Scroll down to Settings and press SELECT
- Select Status
- Select Network Connection
- Scroll right to Network Setup and press SELECT
- Scroll down to Advanced Settings and press SELECT
- In IP Settings, the IP address of the Sky Q box is shown, for example, mine is 192.168.0.7
Note: this 192 address is a local network address that your WiFi router understands and is not an external site.
