11
Discussion topic: Mode not supported
This message was authored by Kat51 This message was authored by: Kat51
Mode not supported
Sky Q mini working until I changed resolution on Samsung tv now mode not supported showing on screen and now sky not working and won't allow me to press home button
This message was authored by MightyQuinn This message was authored by: MightyQuinn Answer
Re: Mode not supported
Hi @Kat51   Try changing the resolution to 1080i by keying in the sequence Home 1 0 8 0 Home. If the remote is not working then reset it by holding down 7 & 9 until you see 4 flashes. It will be in IR mode so make sure the box is not hidden from the remote.
This message was authored by stereohaven This message was authored by: stereohaven
I'm not sure I quite understand why you wouldn't just use the TV remote to change the resolution back?
Pressing Home, 1080, Home on the Sky remote will revert a Sky Q box to 1080p.
LG OLED | Sky Q | EE TV Pro | BT Smart Hub 2 | Apple TV 4K
This message was authored by Chodley This message was authored by: Chodley
They didn't change the resolution on the TV, but on the sky box.
Not sure what res it's possible to set a mini to which a modern TV can't handle though.
Kat51
Because screen black with mode not supported and not allowing sky screen on tv so unable to press Home Screen remote is working as allows  me to turn sky box on stand by
Kat51
Yes changed resolution on sky remote/box now screen black and no sky available
Kat51
Thankyou so much I can cancel my engineer now the lady on phone didn't give me this advise
did you do the "home 1080 home" thing recommended above?
Kat51
Thank you so much problem solved now I can cancel my engineer now lady on phone didn't have this advise
any idea how I change colour on tv guide used to be blue background but now black ?
Kat51
Yes 👍
 you've turned on the accessibility high contrast option.
Kat51
Thankyou for solving another problem lol
