Discussion topic: Missing signal
This message was authored by: Neilcarew
Missing signal
No satellite signal for over 3 hours now. Weather not that bad at the moment. Anyone in the Warrington area having same issue?
Re: Missing signal
@Neilcarew
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️ a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News).
▪️following adverse weather wait times for an engineer will probably be significantly longer
