Discussion topic: Missing programs on mini box
This message was authored by: Sha14
Hi
We had sky q fitted last week and also one mini box for different room however hubby has noticed that he's not got all the sports channels he has on main box. TNT works fine on main box but on mini box says new to upgrade package but we have all sports in our package. Help!
Re: Missing programs on mini box
@Sha14 wrote:
Hi
Hi @Sha14
Just be aware
If you subscribe to TNT Sport through Sky (and pay Sky for your Subscription) then you can watch on Mini boxes (provided you have the necessary Monthly Multiscreen subscription). Also subscribing through Sky TNT Sport in HD is included and Discovery plus is upgraded to premium.
If you pay BT directly for TNT Sports on Sky then to receive TNT Sport on Minis you need to pay BT’s monthly second box charge. One monthly charge covers all minis. Also to receive TNT Sport in HD there is an additional BT monthly charge when subscribing though BT.
If TNT Sports is not your issue then,
Reboot the mini as above.
Avatar for Sha14
Just checked and looks like I pay for TNT through BT!! More false information given to us from retention team!
