Discussion topic: Upgrade to sky q from sky+ 6 days ago. Most recordings lose 2 minutes due to a 'technical fault'
This message was authored by: JCH2024
Last Tuesday our dish and box were both replaced. Live recordings worked immediately. Those from catch up or on demand not until I was advised here to update the software. Thanks.
However in the 6 days since most programs we have recorded or downloaded after transmission have had approx 2 minutes missing. We  get the 'there is  a technical fault with this channel. Please try again later'. Historically with our old box and dish this was extremely rare. Maybe 3x a year in thunderstorms or very heavy rain.
TIA
Avatar for JCH2024
Re: Upgrade to sky q from sky+ 6 days ago. Most recordings lose 2 minutes due to a 'technical fault'
I have checked for loose connections are there were none
TIA
@JCH2024 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
