Discussion topic: Minibox
This message was authored by: Yorkie63
Minibox
Mini bix wont connect
Re: Minibox
Re: Minibox
Hi @Yorkie63
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
